Beocentre 2500 and beolink 5000
Hi everybody,
Today I got a used beolink 5000. I am trying to connect it to beocentre 2500 but it says no contact. Is there anyway to enable 2 way communication on beocentre 2500.
Also somebody please tell me how to set the clock on beocentre 2500.
Any help will be greatly appreciated.
With regards
Faisal
Hi, I have not used these units, but the quick research I did on the Beoworld product site says they should work.
Three suggestions:
  1. check the remote's batteries are new
  2. check the remote is sending a signal by looking at it through a digital camera's view finder - you should be able to see the infrared signals flashing when you press the buttons (and the battery is working 😂)
  3. upgrade your membership of Beoworld so you can download the manuals
That's all I can do ... unless someone with your configuration reads this over the weekend and gives you a better answer
Thanks for the reply. It works in the 1 way communication like a Beo-4. But doesn't work in 2 way. I don't know if the problem is with remote or beocenter. Works perfectly like a beolink 1000, only when i enable 2 way it says no contact. I don't know if I have to enable the 2 way in the Beocenter.
Thanks for suggesting to upgrade my membership, I am already a silver member and have been with beoworld right from 2003. I have downloaded the manual for both beocenter and beolink 5000, but nothing seems to be working of all the permutations that I have tried. Lets hope somebody who knows about the 2 way communications can help me.
Peter are you there ????
Do you have a plasma TV nearby?  They can cause interference with the Beocenter & remote's IR signals.
I don't have a plasma TV nearby. But I do have an LCD TV nearby.
Will it make a difference?
With regards
Faisal
For the heck of it I'd bring the Beocenter into a room with no TV and try the BL 5000 there.  'Assume you've put fresh batteries in the remote.
Try this from
On the Beolink 5000, press 'Programme' on the rear set of keys.  The screen now shows 'Timer Record?'  Using the down arrow key on the inner set of keys set in a circle, press until you get the option 'set clock?'.  You can then key in the time, press 'play' and then you can set the date and year in sequence in the same way.
Cleve
Wasn't there a one-way model of the Beocenter 2500 just like the Beocenter 2300? A Beocenter 2300 with two-way communication has a little IR "window" under the left glass panel, the one-way model hasn't. Could this be the case with your Beocenter 2500, Faisal? 🤔
- Dennis
Hi everybody
Thanks for the replies
Could be the case. But I thought all 2500's were 2 way. What IR window should i look at?
With regards
Faisal
