rhansen wrote:
Fourth pic is the ends of the four cords that come out of the wall. I am assuming these would hook up to a beocenter?? Can I buy adapters for this system to run it with something other that B&O? Or will this system only work with a B&O system? Thanks Again!!
Please REF your other post here.
1.) YES, as Peter mentioned a 9500 would be a nice piece.
2.) Adapters for non B&o: Not exactly... the 2 pin is for local speakers on SPK1. You could clip these plugs off and run the attached speakers w/ anything besides B&o.
The 3 pin is the problem. It is actually used to "drive" the remaining speakers in your house. I am not certain, but if you clipped these as well and disregarded the 3rd wire, you may get something out on at least the first set of linked speakers downstream. I am just not sure and it would seem a shame to tear up an already installed Master Contol Link system.
3.) Per 2 above, your best results would clearly be to obtain and install a B&o piece capable of driving the MCL system. Not sure where you are, but these are rather affordable now. Just get a good one!
With that said, I am curious to know if there are any other components visible in this system? Smallish white boxes with wires going IN and OUT referred to as MCL2A or AV's as well as maybe some larger black, heavy boxes (P's) with power to them? It is possible that they may be remotely hidden or as I am concerned... they may have been extracted... rendering the whole thing well, pretty much dead. [HINT] Can you extract one of the transcievers and see if it is attached to anything?
Let us know what you find and welcome to BeoWorld!
