Beocenter AV5 tv cd-i won’t work
OK, you have found P115 on the CDI Loader board. The cable which plugs into that socket should go to P227 on the CDI unit itself.
Yes that’s correct. I had it removed to clean all the dust on the other side. I also found the “pin” that go’s in the fork witch is next to all the gear weels.
I don’t know what to do with this once i found it. Haha
I still don’t found a wat to fix it.. any idea’s?
