Hi there,
I have a Beocenter 9500 which recently start refusing to play some of my cd's.
It spins up the disks, recognise the number of tracks and then either stops and opens the door.
Or it stops and still shows the number of tracks. When i the press a number it sometimes starts playing after all. The chances are higher if it is not the first or second number on the disk it seems.
It does it with specific disks. Does disks are some new and some older. My feeling is that the longer playtime the disk has the higher the chance on failure.
I tried cleaning the leaser lens with some alcohol, but that didn't seem to work.
Any ideas?
Thanks!
