Beocenter 9500 questions -speaker selection?
Hello all, I recently acquired a used BC9500. I'm primarily using it with lab 6000's as a secondary stereo. I'm wondering if there is any way on the unit to switch the passive speaker outputs off and on. Doesn't seem like there is ( I realize you could use MCL equipment for this).
thanks
Hello Ryan,
I asked a similar question some months ago - you may find this helpful
