Beocenter 9500 phono problem
Hi all,
I have a Beocenter 9500 that i want to hook up to my Music Hall MMF. I have a NAD phono preamp, and a sounds heavenly RCA to Din plug to hook it up tot he 9500.
But when i do, it gets intense interferance and noise when the tuen table is simply turned on. The NAD has MM and MC setting, tried both and no differnce.
ANy ideas on how to get it working?
Does the 9500 have a phono pre amp built in?
Cheers.
Indeed it does.
Cheers, will give it a go and see how she sounds.
Hi impala,
How did you get on? If you need any help or advice, feel free to ask!
Best regards,
Steve.
