Hi everybody,
it's been quite a while, but I just recently was able to check again for that line connection.
Here's what I found:
My solution rigth now is to work with a wireless sender station I had around in my office. This is sending the signal via radio frequency (no WLAN, no Bluetooth) to the recieving active speaker. The radio connaction works fine for my needs (its just some mono sound while doing the dishes, so I don't care too much).
But there's a problem: the radio connection works best if the sender recieves a strong input signal (read: LOUD). Right now it works when I connect the sender to the PowerLink out. This way it is of course affected by the output level in the main room. As long as I play my music at a quite „present“ volume level in that room, everything is fine. But as mentioned in the former posts I want to be independent of that rooms volume level.
It was suggested that I'd use the TAPE2 outs instead which would give me line level. The problem now is that line level has a too low output to give a strong signal for the sender. Which gives a low volume level in the recieving speaker. And when I crank up that speakers volume to the max it gives a lot of static.
IS THERE ANY WAY OF ADJUSTING THE LINE LEVEL?
Hope somebody can help here...
