Hi there,
I posted this question already in another thread, but maybe it was overlooked there as it was at the very end and the original question was already answered. So please don't mind if this comes as a double.
So here is my question:
The 9500 is working in the living room and before owning this one I had a different amp working at the same place supplying music for the living room and two other rooms as well via ONE plain speaker cable and two SINGLE speakers in the other rooms.
Of course MCL should be the obvious solution for this setup, but I still have that humble speaker cable covered up nicely under the floor and I'm quite tempted to use it again and hesitate to switch to an visible cable for the MCL connection (cannot cover it without a lot of hassle). Then I thought about BeoLink wireless, which sounds good but would probably interfere with my WLAN and phone setup and, to be honest, is way too sphisticated for some bits of music in the kitchen and the other room.
Next thing on my mind was to use the MCL outputs for connecting those two odd speakers again, but it seems this could be harmful to the 9500s amp (Ohm-wise). Is that correct?
I thought about other wireless solutions and then stumbled upon sending the signal via my powerlines with Devolo dLan audio. This brings my up to the following question:
Is the line in/out the right choice to deliver a line signal to the powerline connector? It has RCA jacks and from what I understood having a line signal which is not affected by the volume control of the 9500 in the living room would give me the option to have rather quiet sound in the living room and some louder sound in the kitchen. Is that a correct assumption? Then I could simply use a cable with DIN to in/out RCA jacks and hook up the outs to the powerline adapter.
I know that the sound quality via powerline is far from HiFi, but since there is only one low budget speaker in the kitchen I don't care to much. Maybe there's a better option around the corner...or using the analog speaker cable is okay...open for suggestions...
Yours,
Ray
