I have a Beocenter 9500 where the tape holding the lower touch panel glass in place has failed. I've removed the old tape from the plastic frame that the glass sits in and cleaned the sticky residue with Isoproply Alcohol. However, removing the old tape from the glass panel is proving a little tricker. I'm worried about scratching the black paint on the glass not to mention using any form of cleaning fluid on it. Has anyone cleaned the sticky tape off the glass without affecting the painted surface? If so, what did you use. I was thinking of using a citris degreaser. Any thoughts, ideas?
With replacement tape I'm thinking of using 6mm wide thin double sided tape. Any recommendations on this?
