BeoCenter 9500 & a telescopic FM Aerial
Having finally bought a BC 9500 -  the last in my original list of 'must haves' - I was a little surpised to find there is no built-in clamp at the rear to allow fixing a telescopic 'rabbit's ears' aerial.  Most of the other Beomasters and Beocenters I have owned/own have some means of attaching one.
I would normally hook the 9500 up to my external aerial but for domestic reasons running coaxial cable through walls to the Beocenter isn't on.
Anyone managed to attach neatly the standard B&O telescopic FM aerial to a BC 9500?
Cleve
Hi Cleve,
Ah, it's more elegant than the old clamp arrangement.
Check out the back, dead center, on the flat plate guarding the cooling fins that carries the stickers.
There you should find a neat little notch that will accept the aerial.
Cheers, Steve
Thanks Steve,  I'll check it out.
Eyesight's going, obviously.
Cleve
