Capacitor 2103 is to the left of the laser output potentiometer and just above the 6101 chip. They are coloured black on the drawing.
Beocenter 9500
Got it !!! Graham...do you think we could just change that out to the spec that you noted above without testing?? And give 'er a shot??
Gracias..
Hi Graham and others..
We replaced the C2103 with exact replacement.. still not working..
I see in the diagram that there is a TR 6108 (BC 338-16) in the same circut and a R 3116...but in the parts sheet , it does not list a R 3116 for specs..
Any other ideas??
ahhhh thanks Peter...just saw that...3108 to 3138....are just as you say..
