Beocenter 9300 CD problems
Thanks again Graham, I have sent a message to Tim Jarman, are the linear decks unusual?
Not unusual, rather they are the latest version as fitted to newer B&O products such as Ouverture and it's derivatives. I have little experience and no circuit diagram and I have not come across a faulty one as yet! They were fitted to the very last 9300's made.
I am sure Tim will have the knowledge.
Well that's kind of good news, if they are relatively recent, there should be no problem getting the parts.
I have heard from Tim who recommended a B&O dealer, so I contacted the local service centre, they confirmed that it is the overture cd mech, and they will normally replace them in this case. Sadly they do not sell spare parts, is there any way to obtain spares from another source?
Sadly, although you have a later linear laser mech (CDM Pro) even the replacement for that has been superceded by Philips who are the manufacturers of the mechanism.
B&O have developed an upgrade kit which allows the later CDM Pro II mechanism to be fitted. Unfortunately it is not a straight swap of the mechanism but involves fitting a modified CD interface pcb and some soldering.
Instructions are provided in the kit, which I managed to successfully install. As I recall, the kit cost around £100 which I thought was relatively cheap. I would guess that it took me around 2 hours to fit so the total cost of repair by a service centre should not be prohibitive.
I suggest that you get quotes from dealers now that you are armed with this info. The part number for the kit is 8420016.
Alternatively you could try other dealers who may well order this kit for you to fit yourself although they are discouraged from doing so by B&O.
