Hi All,
I have a client with a Beocenter 9000 that wants to connect 4 passive speakers to it. I have the correct 2-pin DIN speaker connections, Speakers two works, but Speakers one does not work. Any thoughts why speaker one doesn't work?
Thanks!
Hi All,
Thanks!
Quite possibly a mute relay fault as this only affects spkr 1. Try cycling mute on/off several times, but you may find that you just have to replace the relay. Search ‘mute relay’ on the forum for more info.
Ahh yes, I should have thought of that. It has been a long time since I have worked with an older unit. Thanks!
