beocenter 9000
Hi I am new to the site and have an old beocenter 9000 the cd cover will not operate and i have got as far as taking the two glass panels and center stainless cover off. The string on one side seems to have come off the runners can anyone tell me how to take the CD cover off so i can access the various pulleys and re thread the string please. The slider worked ok until my son started messing about with it.Many thanks
Hallo Goldersboy!
I underkant av det nedre glasspanel er det to små hull, ett på hver side til hver sin luke. Prøv med en liten flat skrumeisel og drei forsiktig på skruen så vil du se at luken åpner seg (nødutgangen)
Lykke til.🙂
Surferen
