Beocenter 9000 1986 urgently searching for a CD laser or replacement CD
Hi everyone,
I have a Beocenter 9000 from 1986 (Type 2501, NS 04712987). Just took it to my B & O service man and he revised the whole thing, doors sliding perfectly, cassette and radio excellent, but he said te CD laser is finished and he has no more. I would love to buy either a new laser or a complete CD unit from anyone, anywhere. I love my old B & O stereo and don't want it to sit there and not be used loudly as it was designed.
Can anyone please help?
Hello anodyne1,
try to contact "Ulf" from the german beoworld - I think it´s possible that he can help you!
regards, Adrian
Thank you very much. I'll try to find him.
I may have one available.
Neil
It could also mean some capistors and soldering is the culprit with the lazer being fine!
Go to Ulf or Dillen in the workshop before buying another lazer.
If you do I will gladly buy it from you. Thanks.
Thanks. I have contacted Ulf and he is sending the information for this.
Hi Neil,
Did you happen to have the part for the Beocenter 9000? I would like to buy it if you do.
Many thanks.
