beocenter 7700 ffwd tape
Hi. Recently, i replaced the belts of the tape from my beocenter 7700, and now, the tape can play and can rewind, but it's unable to make fast forward. Do you know exactly what to do to solute this issue? Getting deeply in the tape is complicated and i don't want deconstructing the tape unless i know exactly what to do.
Thank you so much.
hi replace the clutch drive unit i think you will find its an Hitachi
Do a search for Becocenter 5000 cassette desk problem. You will find a post from myself explaining the issue and fix, it is an issue of lubrication.
Andrew
