Hello everybody. I'm thinking about buying a beocenter 7002 and I'd like to know the exact wiring for the aux input, since i'd like to plug a cd player using a 2 RCA output from the cd player to the beocenter 7002.
Thanks a lot.
Thanks a lot.
I think you may find it here but not sure:
I think it is standard DIN though. In that case you can have a look at this:
http://pinouts.ru/Home/DinAudio_pinout.shtml
/Lars
Yes it's a standard 5 pin DIN connection.
I recommend getting a ready made 5pin DIN - 4xRCA adapter, then you can just experiment which two RCAs are the correct ones. If you get a 2xRCA adapter, there's a 50% chance of getting the wrong one!
Thanks a lot to everybody. I think information can be very useful.
And what is the button in the Beocenter 7002 for selecting the aux input? I can't see a detailed photo of the panel.
I think there is no button... the input is shared with the P1 radio preset and you'll need to unplug the aux cable when you're not using it!
