Beocenter 6 or Beovision 7-32
looking for a smaller Tv to a guest room and am thinking of either getting a Beocenter 6-23 (I want it in gold) or a Beovision 7-32 but need help to decide. I have the ability to connect it to masterlink where I have a Beocenter 6 in the kitchen as master.
I have spare Beolab 4000s which I could wall-mount for the 7.
A plus with the 7 is the Dvd, then again I hardly watch Dvds but its a cool feature. As I have radio on Masterlink, the in-built radio in the Bc6 is not really a plus. The main advantage for the 6 is if I can get a gold one. HD is not necessary either but I need to connect a digital box (scart is fine).
What do you think?
There is a big difference in size between these two. Which would look better in your room?
both would fit, but placement would be easier with the BC6. The room is approx 4x4 metres.
I would go for the 7-32. It makes a huge difference in picture size. Had a 6-22 in our bedroom for many years and I'm now upgrading to a 7-32 MK3 because the 6-22 is really small. Our bedroom is about 4x4 meters too.
I run both and it's a close call, my 6 23 has hdmi so connects well to my Apple TV and I enjoy the compact size/foot print, picture quality and better TV menu but the 7 just wins due to sound quality and of course slightly larger picture size and DVD player.....
I don't think you can go wrong with either but the 7 to me seems to be a little more special.
