Beocenter 6 26, Type 9282, error codes
Does anyone know what the errror codes below mean shown in the Monitor Service Menu under Monitor Information?
TV 0330 22-2D
TV 0331 40-1
ML TD
ML TD = ML data pulled down (short circuit).
Will have to check the TV errors, but the first four digits are month and date (TV 0330 = TV error on March 30th).
Roger
On March 30th you had an error related to the M2 processor, and to the CTI on March 31st. These are all bus addresses: An IIC bus error means that the communication on the bus fails when the microcomputer tries to communicate with the address in question.
Roger
Hi Roder
Thanks you for your prompt reply ... do you think there is something seriously wrong with the TV or just a one off malfunction?
Berthold
