Greetings, new member here. So at least 10 years ago I took my Beocenter 3500 in for service. Not sure I remember why but I do know they said it was beyond repair. Turntable motor was done & no replacements available. In addition, right side channel was out & "not worth fixing". So into storage it went, simply to good to look at to throw away. Recntly I decided to play around a bit. Gave it a good cleaning inside and out. Removed TT assembly per instructions I found here with the help of the downloaded service manual, thank you silver membership. I even took apart the front panel for a thourough cleaning & to improve the sliding controls. All put together minus the TT assembly. Here is what I have found. Tuner works but sound does not come out of right side speaker. Also, the tiny "nub" on the tuner wire - the one that catches the sliding control - is gone. So slider does nothing. Top is open so I can tune manually but that will need fixing. But, to my great surprise when I hooked up a different TT (5500) it plays perfectly out of both speakers!! Yes! So my research here indicates a TT motor bushing rebuild including the infusion of new lubricant. But where to start with the tuner issues? It looks like any work that gets done on this will need to be done by myself. So thank you in advance for this great resource - and I hope to get a lot of fresh advice to make this beautiful B & O fully functional. Oh by the way my speakers are S45-2, with stands that I purchased new around 1980 when I bought the used Beocenter. I am currently sandblasting / repainting the stands as they had acquired some corrosion. Thank You pets! The 5500 TT is part of a complete 5500 system donated to me with several issues. But that is another story - at least the turntable works!:)
