Hi - hope someone can help, the doors open when the unit is switched on at the plug and then stay open with light on. While plugged in they can be manually closed but do not open with wave of hand.
If I leave open then turn off at the plug then back on quickly they close, then if I turn off in the same second they stay closed.
I don't think they need lubricating as above they seem to work.
Please help.
Leigh.
