Beocenter 2500 Doors stopping suddenly
i own a Beocenter 2500. I changed the belt and greased the doors slightly with silicone grease. But i have a problem with the doors, that doesn't seems very common.
The doors open smoth and but sometimes. when they should close, the stop after a few milimeters. Only sometimes and totaly random. Without a pattern. So i guess, it should be an electronic problem?
Don’t grease it, do adjustments on the top and bottom
Ah, the aligmet. Ok, thanks. I`ll try this.
Hi
at least mine is very sensitive to position of those parts which are fixed to doors. Have had two 2500 and in both of those I had to glue those holders back. If it's done already once before you should first try to take old glue carefully away as much as possible. After that's done and right positioning of those holders doors will probably move as they should.
