BeoCenter 2300?
Where would be the best place to source and what type of cable is it?
thanks
It's just a standard datalink cable. they are 7 pin din plug at each end and wired pin 1 to pin1, pin 2 to pin2 etc, and I'm guessing with each audio signal screened separately (but it's been a long time since I've examined one that closely).
You could obtain the cable from sounds heavenly or from your B&O dealer.
Kind Regards,
Martin.
Thank you
If you still want to use the AUX Port on the BC2300 with the Konverter, you would need a Y-cable additionally. I have an Apple Airport and ML Conveter connected to my BC2300.
Cheers,
Frank
