Beocenter 2 power failure
Is the socket set in an open position or the right way up so that it is well ventilated? Is it overheating?
Can you deactivate the PIN when it is working? Will it now stay on?
Can you put it in service mode? i.e. when a PIN is asked for press the double left arrows 3 times to get to the 'Master PIN setting' and enter '11111'.
Sounds like some sort of thermal protection issue possibly.
Dave.
Possibly a loose connection somewhere then is most likely. Hopefully it will continue to behave.
Dave.
