BeoCenter 2 Mark I vs. II vs. III
Hi there.
I've looked high and low, but haven't found the answer.
Does anyone have a definitive answer to the difference3 of the three revisions of the BeoCenter 2?
Specifically, I'm looking to buy a used BeoCenter 2, and want to make sure that I get the most capable system, and buy one that either has, or have the possibility of retrofitting a DAB+ tuner.
Iøve also heard something about a Bluetooth option for A2DP streaming, is that an official solution, or a third party upgrade?
Thanks, Mikkel.
Hi Mikkel,
To my knowledge there are only two versions (mk1 & 2) plus the audio-only version (no scart)... and the aluminium and steel versions, which looked the same to me unless compared side-by-side. The DAB+ was introduced June 2010 (mkII + audio version).
The introduction of the tactile feedback when pressing the buttons on the mk2 was a big bonus (they installed a small speaker that makes a "click" sound when you press a button) in my view.
The BT-option must be a third party thing?
Roger
Hi Roger.
First of all thanks for your reply:-)
I could've sworn I saw a mentioning of a mark III in a pricelist containing prices for upgrade modules. But can't find it now:/
Anyway, from what you're saying I conclude that if I purchase say a 2008 without DAB, it's safe to assume that it's a Mark II, has the tactile feedback, and can have the DAB+ retrofitted?
If that's the case it just made it a whole lot easier finding a used one at a decent price, and have the DAB+ upgrade done.
Thanks again:-)
Cheers, Mikkel:-)
