Beocenter 2 help needed - power cable doesnt fit socket box!
Hi all
today i received delivery of an ex-demo beocenter 2, and socket box. however when i took it home, i tried to plug the power cable into the power socket on the socket box, and it wouldnt fit! the power cable is a figure-of-eight shape, whereas the socket hole is a slightly different shape.
i dont know if the metal plate that is put on the socket box has been put on off-line/off-centre, or if i have been given the wrong/old cable for the socket box. i have attached photoss of both the power cable and the power socket connection.
any ideas?
kevin
the power cable
Well that socket is the same shape as all of my B&O, try harder to get that plug in, i do not see how it can't fit - don't be scared to jiggle a bit and use some force!
The socket is definitely crooked, but there should be some movement for you to jiggle the plug in
kevnick80 wrote:
Hi all
 any ideas?
 kevin
Just press harder :)
I had the same "problem" with my beolab 10 speaker, it had the same connecter as your panel, and in the BL10 box was the same figure 8 cable as on you picture.
They will fit, you just need to jiggle and press a bit harder.
/Weebyx
are you sure i should cut it or it will definately fit?
as you can see in the socket photo, the top part of it is squared off/flat, not round, if you get what i am meaning
how much of the plastic can i cut off of the cable without affecting any metal/wiring?
thanks
OK, it has nothing to do with the square shape of the socket. That is normal and does not affect the fitment of the plug, you need to roll up your sleeves and try to jiggle it in (push the plug in at an angle to get around that over lap), because as you can clearly see in the photo, the product has a fault in it's build and the metal casing is interrupting the socket...
If  that doean't work and you want to cut it, just use a stanley knife and shave a bit off of one of the flat sides of the plug, for it to squeeze through the faulty casing to the socket. (FYI you can cut off quite alot, but it isn't nessisary to cut that much, as the overlap on the socket isn't very big.
head down to your local radio shack or its equivalent and get a new plug
some B&O products have the figure 8 and some have the square on one side
you can get the plugs at a local electronics store and they work fine
I've done that on many occasions.
MJM
they sent you the wrong power cable... you need a "Square / Round" not a "Round / Round."
with that said... the one you have can be modded as dave mentioned... or just buy one locally... they are cheap and available most anywhere!
hi all
dorted - ended up having to shave off quite a lot of the plastic off the plug then jam the damn thing in
but hey, it has power, but still trying to figure out how to work the beo4 and the beocenter 2 itself as the B&O dealer did not include the manuals! clever eh....but i believe they are on their way
thanks
Guys it wasn't the cable, click on the first picture, it was taken with a glotious camera, you can see the fault of the product, a couple of milimetres of the socket is covered!! The square socket accepts the normal fig-8 cable. :)
kevnick i would have taken the thinkg back to B&O to fix for you under warranty as it was a fault on the product.
