BeoCenter 2
Hello,
I have in my bedroom a BeoCenter 2 and a Beovision 5 connected, in the living room a Beosound 5 and Beovison 7, which serves at the main room. The bedroom is connected wireless to play music on the BV 5. Does anyone know if I can integrate my BeoCenter 2 so I can use the buttons on the BC2 to activate radio and cd from the BeoSound 5?
Thanks for your help
Hi Martin and welcome to Beoworld!
I hope someone more knowledgeable than I can answer your problem: I also have a BC2 connected to a BV5 but no BS5.
If you have the manuals for your equipment then you may find a Masterlink solution. Can anyone else advise Martin?
Graham
The first question is, are the bedroom and living room systems connected together by Masterlink? If no, you will need to connect them. If yes, have you renamed your N.Music and N.Radio functions on BeoSound 5 to Radio and CD? If yes, you will not be able to control it from the BeoCenter 2. If no, you can access your BeoSound 5 from your BeoCenter 2 with the Beo 4 by selecting N.Music or N.Radio from your List button. You can also go into the menu(List) of your BeoCenter 2 and add N.Music and N.Radio as a function. Once you have done that, you can exit and hit List on the BeoCenter 2 and you should see N.Music and N.Radio. Hope this helps.
Joe
Thanks, that did work. Can the BC 2 display what's played from the linked BeoSound? Thanks again
I know it does with BeoPort, I have yet to try it with BeoSound 5. In theory is should :)
It did work when it was connected directly, but wirless it does not. Can that be right? Thanks
