Beocenter 1 Timer
Hello everybody. I hope you are all good.
I have a question which I posted in the german forum but nobody seems to have a clue.
I recently bought a immaculate Beocenter 1. This Beocenter does not have the timer function which I would like to use. What do I need to do to get the timer working. Has it something to do with this ML card? Can I make a software update? The software is 3.0. Type is 8510.
I hope somebody can help me.
Regards, Noah
Very likely - possible reasons:
1) ML built in - but wrong option settig eg. "V.OPT 6" for using the BC1 as a link room TV
    Solution: change option to "V.OPT 1" or "V.OPT 2"
2) NO ML-card
    Solution: try to get a (second hand) Master Link Module Type 4015
