Beocenter 1, no on-screen-menu
I have just purchased a Beocenter1 but I cannot access the OSM I have tried all instructions as per the guide etc. Does anybody know if there is a master reset switch or am I doing something wrong here, all the DVD OSM work fine while watching DVD but not while in TV mode.
Any help would be appreciated.
John.
What is the typenumber of the BeoCenter 1?
Type no is 8503
In that case you have to choose the MENU via the display under the picturetube. So press DISPLAY on your Beo1 (or MENU on your Beo4). Now the red display under your picyure tube will show a source. Now keep pressing << or >> on your Beo1 or Beo4 untill the display shows MENU and press GO after that. Now you are in the menu!
Many thanks, I will try this tomorrow and let you know the outcome.
Thanks again for all your help.
John.
Blackrix you are a star!! thats done exactly what I wanted many thanks.
John.
Glad to be of help!. Have a lot of fun with your BeoCenter 1!
I've got a beocenter 1 and am so so pleased with it.  On a video stand it looks so good and the picture quality is fantastic.  Have a BS3000 feeding it for stereo and I love how it displays culume and track number etc!  Hope you are pleased with it too!
