Beocenter 1 issue
Hi
My beocenter 1 turns off by itself after a while and then stays in stand-by
It doesn't respond. I unplugged it and after a while I could turn it on. It started in the configuration menu
Can it be the software only? How to access the service menu and where to find the instructions to follow and the pin?
Or is it the hardware? I suppose to get it fixed would cost more than to buy a new led tv today.
Is the a market place for default equipments
it could be the power board, its fairly common! a few people might have a better idea and let you know, good luck
thanks,
I found in a Forum that it might be the capacitors from the power supply board indeed.
I called the B&O service center. They'll tell me how much it costs to change the whole electronic piece. As I suppose it'll cost a lot I'll have to see if there is a fix to the power supply board.
