As title says, it ejects continuously even without a disc in it. The sensor for ejecting/loading underneath the front fascia seems to work ok. I dont know if it's dust in the drive or a sensor error. I sprayed compressed air into it but no luck. If it's a fault, can I just disconnect it from the circuit board or will this make other things stop working?
Regards,
Andrew
