Beocentar 1 + STB
Under MONITOR INFORMATION
  • Software version numbers
    The “STB SW x.x” line is only shown if the M2 Processor, 1IC200 SDA6000, is fitted with set top box controller software.
    The “STB TABLE xx.x” line shows the version of conversion of set top box remote control codes into Beo4 codes.
OK. We are all making this overcomplicated!
Turn on the TV with the TV button.
Press Menu to bring up the TV Setup page.
Scroll down to Options.
Click, and next page is headed Options.... Select Connections
In my case the next page shows V Tape assigned to V Tape, and AV asigned to STB. (You may have to play around to get STB to appear).  Select the STB, you will get a Settings Stored page, and then the list of STBs already loaded into your TV will come up. In my case it is Force11455/895, Sun Moon Star, Casema Selector, Panasonic TU-CT20, Strong Sat 5200, Teleclub, Vistar 3000 HKG, GI500, but no doubt the STB's already loaded will depend on what the original dealer put on if there wasn't a factory default selection.
So you don't need the service menu to find the STB list (assuming the module is in the TV).
Graham
Thank you Graham !
That's the way you should talk to architect 🙂
Found it and have a list, i'll try to find some still available units ..
Keith, thanks ! My unit only show STB TABLE 2.8
Best,
Nikola
