Hi all,
One old fashion problem :)
I have Beocenter 1 that has built in STB controller. And I want to make it work with STB I need to buy. As I understood I need one cable called IR transmitter which will be connected to IR out and than connect to STB. This is the part I understand.
Thing is how to get adequate STB for my Beocenter 1.
Is there any source where I can look for info about supported STB ?
