BM5/BS5Was the software in BS5/BM5 updated or the CTconfig tool for Beo6?
I do not have any update pending in my BS system anyway.
//Erik
//Erik
Hi Folks,
To get the Beo6 work properly (with playlist+big cover art), restore the Beo6 remote (by pressing the off, then the ok button, then Settings), configure again the WiFi. Exit. Try, if it still doesn't work, use the Config Tool, remove BS5 and enter it again. Serialize... and then everything should work!
Cheers
Hi
I can confirm that it really works. Not the configuring of the WiFi but the latter - to completely remove the ConfigTool and reinstall it again did the trick! Completely = uninstall in Windows is Not enough. You have to delete the whole library and then make a fresh install!
Thanx Griebel!
//Erik
PS. I changed the language to Swedish after I got a fresh english install to work. It then stopped working - so do not change the original language is my advice.
It works fine now for me also, I updated the Config Tool and so far it shows everything as supposed :-), Brgds Ingvar
