Hi there,
can someone tell me/us, which functions are available if you have a Beosound 5 Encore / Beo6 setup?
Best regards
Stephan
Hi there,
Best regards
Stephan
Very cool!
Finally.
Hi there,
Best regards
Stephan
Nothing new as it is currently only updated for two-way with the BeoSound 5 ... not Encore.
Does anyone know if it works with 802.11n networks or if it only works with G networks?
Also, will this come to the Encore as well at some later date when they have rolled it out for the BM5/BS5 combo?
The first product to support the functionality of the new Beo6 firmware is the BeoSound 5 with BeoMaster 5.
The following are the key features implemented so far:-
Other facilities which were actually introduced in Configuration Tool version 4.11 but most people do not appear to have noticed is that you can:-
How do you scroll through albums? Buttons or spin the wheel on the Beo 6 like on the Beosound 5?
Gestures on the screen like an iPhone.
2.11 is not new version!!?Yes, it is available now on the B&O intranet (sw v 2.11a).
Roger
