beo5 to beo 6
is it possible to update a beo5 to beo6?
Yes it is.
If a Beo5 gets a faulty screen, the screens are no longer made, so B&O produced a kit to upgrade it to a Beo6
and then have we got the wifi?
what is the price of the kit?
Yes, you do have WiFi once the new firmware is downloaded into it by your dealer
That sounds promising - any idea of the cost?
Peter
In my neck of the woods the cost was so high, that trading in the old Beo5 for a new Beo6 turned out to be a better deal. Check with your dealer (if the workshop charge you by the hour for the repair you are better off getting a new one IMHO).
Roger
