Hello, I would like to control my BT vision box with my Beo5.
The Beo5 is already programmed with the BT vision commands.
But I understand the TV has to be programmed as well and I need to select from the STB list for the IR controls the BT vision, which is not in the list.
Is it possible to update the list of the device to control through some software without bringing the TV (BV 7) to the dealer?
Any idea anybody?
Thanks!
