Beo5
Hi all does anybody know how to set an option 1 or 2 on a Beo5 i wish to set my Beocenter 6 to option 2 many thanks
i think if you press the centre buttom and the power off bottom at the same time you enter a little "service" menu. The letters should go red. Then you press config or something and it does it all for you automatically...
