I purchased 3 replacement rubber keypads for my BEO4 about 3 weeks ago from the B&O shop in Beaconsfield, Bucks. the problem is that the GO and DTV have started to rub off, the previous keypads had lasted 4 years before the lettering stared to fade, but these all 3 replacement have gone, its like the lettering transfers are starting to peel.
Should I contact the shop for replacements.
Jon
