Bonjour,
Anyone would know if and how I can adjust loudness, treble and bass on a Beomaster 5500 from a Beo4?
Regards,
Alain-Olivier
Montréal
Bonjour,
Regards,
Alain-Olivier
Montréal
Bonjour!
Add 'A.SETUP' to the list on the Beo4. After you have added it to the Beo4 list, press list until 'A.SETUP' appears, press 'GO' and then press list agin and 'BASS', 'Trebble' and 'Loudnss' can be accessed. Once the desired parameter is shown on the Beo4 display, press 'GO' and then use volume up and down button to adjust the parameter. However, the settings made this way will not be stored after the beomaster is put to standby. I do not know how to store since there seems to be no 'STORE' command on the Beo4 like there is on the Beolink 1000.
Not with mine at present, but pressing GO twice might store it.
Found it! 'S.STORE' is in the 'A.SETUP' sub menue along with bass, trebble and loudnss, simply press list until A.STORE appears an then press GO and whatever changes made to the sound will be stored. Strange that i did not see that before, probably stopped pressing list after i found bass trebble and loudnss. Happy soundtweaking!
Worked as a charm, you are the best. Thanks
Alain-Olivier
