Beo4 Now Sold Out
Daily.
I use two: one for my BV6-26, one for my BV9.
But I don’t like the Beo4. I would choose a BL5000 if B&O still made 2-way IR.
I have 5 - Almost 1 in every room,
I use Beo 4s in 4 rooms, BeoRemote 1 in the 5th room. I have always been a big fan of the Beo 4, but recently have found myself wanting to replace them with BeoRemote 1s. I have grown to like the BeoRemote 1 better. But as long as the Beo 4s work, I will keep using them.
Used on a daily basis. Got my first one back in 1997 with an MX7000 as an addition to the BeoLink 5000 I bought (at an ridiculously expensive price at that time) with my Beosystem 2500. Still have several of them from all generations. Same applies to the BeoLink 5000 even though the display died a couple of years ago. Liked the Beo6:s too but not as an everyday remote as the Beo4. Both of the Beo6:s are also sadly gone now due to the known battery drain issue...
Has a BeoRemote 1 BT for my eclipse now and even if there’s more functionality in that remote than the beo4:s, I actually prefer the look, feel and button layout of the beo4. It is a lot easier to find the buttons.
I do too ! I have 10 (all Navi) and all used almost daily from the one in the garage and from there through the house, his and hers in the Master Bedroom. Only two which are used less are the two in the guestrooms.
Add 3 beo6, MCP6500 (used daily), BL7000, BL1000 and a Beo1
Beo4 is close in first place just before BL1000,
Can't imagine having BR1 as al my lights are controlled with an easy Light + Colour Button. Two presses, how easy can it be without even looking at the remote.
Again, an end of an era ;-(
Daily.
I prefer it over the Beoremote One. Beo 4 feels much better!
Is that a standard feature, or does it need some additional equipment ?
Will the price of used ones now creep up or decline? Seems that last I looked on eBay they weren't going for as much as they had been.
That was the B&O Lutron system unfortunately now out of production but you still can find them.
-Either stand alone B&O Rania dimmers
- Or multiple and connectable multizone B&O Grafik Eyes
Solid as stone quality, even compatible with led and led dimmable (not all maybe)
