Beo4 for BV11
I tried to setup BV11 to be controled by beo4….then tried 1 and 2 and 4 ….Beware that when you choose 4 both remotes (beo4 and beoremote1) became “dead”.
It was a full story to recover access to bv11:)
I tried to setup BV11 to be controled by beo4….then tried 1 and 2 and 4 ….Beware that when you choose 4 both remotes (beo4 and beoremote1) became “dead”. It was a full story to recover access to bv11:)
Strange, there seems to be another problem! I used to haven 2 BV11 and I could control them with all 3 mentioned remotes. And that should be the normal behaviour! What do you mean with remotes became dead"?     From the BV11 manual:
Suddenly I understood what you meant:
You are setting the BV11 options to 1, 2 or 4.
With 4 they are not dead but they should give a additional "LINK" command. The remotes should be set to do this.
You should go, to choose the right Beo4, to the second picture of my previous post.
Leave the option of the tv in option 1 or 2!
After changing BV11 from beoremote1 to beo 4 you have another tab active, with 3 options : 1,2 and 4.
i thought that they ar eequivalent of Modes of beoremote so I tried all of them in order to match the beo4 mode (that I cannot find in setup to change)
When I selected 4, both remotes became unresponsive….I couldn’t change anything in bv11
i will paste what chatgpt instructed me to do, and it worked:
● + LIST → OPT? → GO → V.OPT → 1
It control it (start/stop/vol/etc), but if I open menu or program list I cannot scroll
Have you tried my suggestion about controlling the TV using the B&O app?  Your TV will need to be connected to a network for this to work.
If you do manage to connect to a network with internet access, you may be able to download a SW update for your TV that will then allow you to choose a 'no navi button' remote control option.
Yes, I can control BV11 on BO app, but wife is not happy with phone controls:)
I assume new beoremote1 displays with 4 buttons can be matched with old aluminum frames….I am still thk if I should buy a new beoremote 1 or just the display/buttons panel
