Beo4-Controlled Raspberry Pi setup for streaming Net Radio on BeoLabs
Sharing some experience.
Wife wanted to play (net)radio on the kitchen Beolab 3s by pressing one button on the Beo4.
The solution:
Beolab 3s
Raspberry Pi running 'Volumio'
B&O Link Eye
Works like a charm. Pressing RADIO starts the favorite radio station and other stations can be selected by pressing 1-9.
Thanks for that tip!
I guess most of us will need a bit more information about that/about how to control that with ‘the remote’.
I can share that.
Download 'volumio' and burn the image to an SD card.
Boot up your pi. On the monitor connected to the pi, you can see what IP the pi got on your network.
Access the 'volumio' frontend via the  browser on your computer. Register a free account. From the web frontend you can now install the IR remote plugin. And in the 'volumio' settings you choose your audio output. I use minijack.
Connect the B&O IR Eye to PIN 2, 6 and 12.
Pin 2 is +5v
Pin 6 is ground
Pin 12 (called GPIO 18) is data
In the IR plugin on the 'volumio' web frontend select GPIO 18 and save.
All that is remaining is to create a folder with the name 'Beo4' in a specific folder on the pi. The web frontend defines where.
In that folder you place two custom files which tells the pi how to decode the signal from the B&O IR Eye and what to do when a specific button is pressed.
When the folder is created and the files are saved in the folder, Beo4 will appear in the remote control list. Select and save.
The files are called:
lircrc
lircd.conf
Now restart the plugin.  A bit of flair for Linux, ssh and command line is an advantage.
I will share my 2 config files. That will make it easier to get started and modify for your needs.
Hope this guide helps.
Link to GPIO overview:
https://cdn.sparkfun.com/assets/learn_tutorials/1/5/9/5/GPIO.png
I have tried to upload the config files... but it does not seem to work 🙄
Hi Ravsted,
I'm a bit late to this thread, but I would be very interested in using your setup.
It sounds very interesting to use Rpi to control radio, music, etc.
I need it for a Beomaster 7000, where you can get datalink commands directly from the Powerlink outputs.
I currently use Beomaster 7000 to control Beosound 5 / Beomaster 5 via Beolink converter 1611 (AUX-link <> Masterlink connection).
I understand that you have problems uploading the configuration: could it be that it is larger than 31 MB, which is max. upload size?
Kind regards,
Jens
Jens Rendboell
lircd.conf:
begin remote
  name  /home/osmc/beo4_ireye_pc.conf
  flags RAW_CODES
  eps            50
  aeps          150
  gap          2000
      begin raw_codes
          name KEY_UP
              1562    1562     1562    1562     1562   14058
              1562    1562     1562    4686     1562    4686
              1562    4686     1562    4686     1562    4686
              1562    4686     1562    4686     1562    7810
              1562    7810     1562    4686     1562    4686
              1562    4686     1562    1562     1562   10934
              1562
          name KEY_DOWN
              1562    4686     1562    4686     1562   10934
              1562
          name KEY_LEFT
              1562    1562     1562    4686     1562    7810
              1562    4686     1562    1562     1562    4686
              1562    7810     1562    1562     1562   10934
              1562
          name KEY_RIGHT
              1562    4686     1562    1562     1562    7810
              1562    1562     1562    4686     1562   10934
              1562
          name KEY_RADIO
              1562    4686     1562    7810     1562   10934
              1562
          name KEY_STOP
              1562
          name KEY_VOLUMEUP
              1562    1562     1562    7810     1562    4686
              1562
          name KEY_VOLUMEDOWN
              1562
          name KEY_POWER
              1562    4686     1562    7810     1562    4686
              1562
      end raw_codes
end remote
lircrc:
begin
prog = irexec
button = KEY_STOP
config = /usr/local/bin/volumio stop
end
begin
prog = irexec
button = KEY_POWER
end
begin
prog = irexec
button = KEY_RADIO
config = curl "http://volumio.local:3000/api/v1/commands/?cmd=playplaylist&name=P4" >/dev/null 2>&1
end
begin
prog = irexec
button = KEY_VOLUMEUP
config = /usr/local/bin/volumio volume plus
end
begin
prog = irexec
button = KEY_VOLUMEDOWN
config = /usr/local/bin/volumio volume minus
end
begin
prog = irexec
button = KEY_LEFT
config = /usr/local/bin/volumio previous
end
begin
prog = irexec
button = KEY_RIGHT
config = /usr/local/bin/volumio next
end
Using Essence Remote for start/stop/vol+/vol-
