Bonjour,
Can Beo4 be programmed to control a Beomaster 5500. And also can I use a MCP 5000 on a Beomaster 5500. Will I have access to the all the functions of the Beomaster 5500?
Regards
Alaiin-Olivier
Bonjour,
Regards
Alaiin-Olivier
Programming the radio presets will need some tricks and be highly annoying with only a Beo4 at hand, but after that it'll be just fine for daily use. You'll be able to use everything except the timers.
MCP5000 would be totally useless in this context, it only works with Beomaster 5000.
