BEO4 & Sky + STB (Thompson)
The Pace Sky+ codes should work. It certainly worked with my Amstrad (till it blew up!) Does the remote light flash on the Sky box when you use the Beo4? I take it that the Sky+ remote works fine? Try altering the position of the IR blaster. You can see if it is working by taking a picture with a digital camera.
OK good I can rule out the coding and stick with the Pace Sky+ option. The remote light does not flash when I use the Beo4, I have continually pressed the SAT or Go button on the remote and moved the blaster around and away from the eye on the box but it will not respond, if I press and hold the Sat button and then take a picture what should I see
M. Clements
The end of the IR blaster will light up - should be a pinky colour!
can't see anything happening the cable must be dead, looks like its time to shell out £27, thanks for your help anyway
M. Clements
