BEO4
I have at least 2 BEO4 hand sets that no longer work.  Someone told me they can't be repaired.  Now that would be tragic.  Does anyone know if they can be repaired and who can do it?  I live in the UK in Surrey.  Hoping to hear some good news!!  Thanks.
Rod.
What is wrong with your BEO 4?
Is it the Lcd?
Or the circuit board?
Or Both?
You can buy the Lcd or You can buy a new circuit board for the BEO 4. Comes with new Key Pad as well,then you just have to open up the remote and do two solder joints then your done.You will have a as new BEO 4.
Easy to do as i have done afew times.
Just don't touch the new strip on the  bottom of the lcd with your hands.
Hope this helps?
Hi, thanks so much for your response.  The LCD in one is fading but it still works.  The other one has a good LCD display but it simply doesn't work any more.  I don't have soldering kit and wonder if I could commission you to do this for me?  Obviously I would pay handsomely!  Rod.
You have a PM.
already tried new batteries?
Yes, tried new batteries.  No luck!  Can anyone help me repair my two handsets?  Rod.
where are you located?
Hi Rod, sent you an email.
Jonnie
