Beo Vision 7 mk IV and My sky
Hi hall,
I'm new in this forum, I'm  italian boy and I don't write a good english...sorry.
Today I have try to connect my sky HD to my beo 7 with a hdmi-hdmi cable +dvi adaptator but i see nothing black screen.I try to connect my notebook and start.I dont' understand someone help me plase?
Thnks a lot
Danko
Mk4 BV7 should only need HDMI- only the Mk1 and Mk2 needed a DVI connection?
My Beo vision have a one DVI connection and nothing HDMI.But I dont't understand how config for my sky hd.There are some trouble with my sky hd?Some experiene?
Thanks.
Thanks.
This indicates that your TV is a MK1 or MK2 version not a MK4.
  Jonnie
As far as I know, ALL Mk4 7-40 TVs are HDMI.......so you may have Mk1 or Mk2??? Check it on back/Reverse of TV...its  written behind a panel on back.
Hi
For someone who does not know where to look the hdmi connections could be missed. I did not initially find my first time I looked.
Wha is the type number of your set this will help others to find out exactly what one you have.
The set has dvi on the earlier model this is input.
Later models it's the output for Beamer.
Quick way to check is to go to connections menu and look at av1 and see if you have hdmi in the list.
