... hey;
It´s a 9572-Type: D´you mean the connector or the plug? So would you think about a defective LVDS-Cable or a defective PCB / Connector-Mount?
... hey;
OK, you have a Mark 2 version.
PCB 14 J17 - LCD panel.
Can be the cable itself or its connection into the plug.
Yeppp. It´s a MKII - And, if i then understand you correctly - that means that the connectors mounted on the PCBS (Main-PCB / Display-Controller) should not be affected. So getting a new LVDS cable might be a hint? ^^
If that is the cause then i´ll give you a private message. Think i´ll get some champaign for you then ^^
