dear all, I have the remote associated with an essence MK2 and only the volume works, when I click on mute or stop, the remote stop working as long as I don’t pair it again.
is it normale? How can I fix it?
thanks
andrew
thanks
andrew
Andrew,
Is the firmware on your Essence up to date? I went through a period of almost a year where the Essence remotes were practically useless. Problems exactly as you describe: after re-pairing, the volume would work, but pressing a button would end communication until a new pairing.
Last fall (I think) a newer version of firmware was released which fixed all the problems with the Bluetooth connection. My remotes work perfectly now.
-Alex
Alex,
should I update the remote or the main unit? Can you pls advise on the procedure?
the firmware I have is 28/2/2018 so it is the last one.
Any other thoughts?
thanks
andrew
My behaviour is not quite like yours. My volume and track skip worked. Then I did pause / stop. After that my volume did not work but start, track skip, and pause did work. Like you my version was automatically updated at the end of February ... Login to view imagedear all, I have the remote associated with an essence MK2 and only the volume works, when I click on mute or stop, the remote stop working as long as I don’t pair it again. is it normale? How can I fix it? thanks andrew
I couldn’t believe it but it was because of batteries.
you are a genious!
thanks so much for your help. The new software update works perfectly.
regards
andrew
Last question...how can I stand by the essence and the speakers from the remote?
from the app is quite simple and the speakers disconnect automatically after 2-3 sec, but from the remote? If I mute the speakers keep on
thanks
andrew
Try a long press on stop, if I remember well...
