Spoke with someone from a local Bang and Olufsen store who has helped me in the past with network issues. We troubleshot my system and everything is in order. He told me that this happens in his store as well. Basically any network interruption may trigger this. He said he would report it to Bang and Olufsen to alert them and see if it becomes something they want to consider in future firmware updates.
Beo A6 and A9 - randomly popping sound as if they are reconnecting
The random beeps usually means its reconnect to your Network, it ether poor wifi or som think like a microwave jamming connection.
Try this app: https://itunes.apple.com/dk/app/beotool/id1068472522?l=da&mt=8
This will show all the info you need to troubleshoot the speakers.
It will show info about the wifi connection make sure its like Good or better.
In som cases it can all so be a overflow of traffic on the network, if the only router you got is from your ISP you should consider buying a more "hi end" router like Cisco and let that do the work.
Hope it helps.
/ Bjørn Andersen
Bjorn,
Thanks and yes I had used that and all indicators suggest everything is working well.
